modelling for Hertz Pressure analysis
Updated by Altair Forum User
Hi All,
I want to model two cylinder in contact (one is in the other one) for analysing Hertz pressure.
1. What kind of contact must i define ? or fixed contact is enough ?
2. At the Result of analysis, how can i display the Hertz pressure ?
3. Any documentation as a tutorial ?
Thanks in advance...
1 - 4 of
41
Mr Rahul,
Thank you for your help. How can i reach the documentation related to the examples what you sent ?
I can't find from the HyperWorks HELP.
Altair Community Member
Updated by Pranav Hari
You can refer two below example from OptiStruct example guide.
OS-E: 0185 Rubber Ring: Crush and Slide Using Self-Contact
OS-E: 0165 Contact Smoothing With Two Concentric Rings
