TCL ClosestNode and CSV Help
Hi All,
I am trying to extract nodes from a user selected component into a CSV. I am very new to TCL so I have been struggling with basically the whole process!
The way I would like this to work:
- User runs the script and is prompted to select the component they want
- Script:
- Isolates the component
- Displays all nodes on the component
- Exports the nodes ID and coordinates into a CSV
So far my code looks like this:
puts 'Please select components'
*createmarkpanel components 1
*isolateentitybymark 1
*createmark nodes 1 'displayed'
hm_createmark elems 1 advanced displayed
set id [hm_getclosestnode 0 0 0 1]
My problem now is that I do not think the closest node code is working correctly, and I am unsure how I would export the closest node(s) into a CSV. (Eventually I hope to ask the user for several locations, and hence I will be exporting several node locations into the CSV).
Any advice would be greatly appreciated!
Hi BurntPixel,
Easier way is to get the component ID and get all the nodes directly from the component:
set lst_nodes [list]; puts 'Please select components' *createmarkpanel components 1 if {[hm_marklength comps 1]} { set n_compID [hm_getmark comps 1] *createmark nodes 1 'by comp id' $n_compID if {[hm_marklength nodes 1]} { set lst_nodes [hm_getmark nodes 1]; } } if {[llength $lst_nodes]} { foreach n_nodeID $lst_nodes { set lst_coord [join [hm_nodevalue $n_nodeID]]; # file operation to write nodeID and lst_coord should come below this. } }
nodes will be saved in a tcl list lst_nodes.
Regards,
Livil
