Only show warpage element
I know we can check elements in HyperMesh.
And we can also see the warpage of elements.
But if I just want show warpage elements, how should I do.
Because now I just can show the warpage elements with other elements.
If I want show only warpage elements, I need to mask other elements in manual.
So how can I do. Really thanks.
And other question is about can we have other instruction to show the elements not equivalence edges?
I know we can use the tool>edges to show elements edge, but sometimes it still have elements not merge.
1 - 2 of
21
Save failed elements and go to mask and select elements > retrieve > Mask > Reverse.
Thank you
