need some help
Hi my name is Fernando Zúñiga, I´m Engineer Mechanical, at the moment I'm doing my research project for my master's thesis, the topic is about desing of a linear motor with permanent magnets.
I´m doing some simulations in 2D, in flux 12.3.1, i got the results and until now everething its ok.
but now i have to do the same, but the simulation have to done in 3D and i try to learn how use the software, I am doing this tutorial, 'Geometry and mesh tutorial First steps in using Flux 3D basic example' .
and everything have going fine until the page 89, when the tutorial says build the volumes.
and in the output shows me this error ' buildVolumes executed Some intersections may not have been detected' I have only followed the steps that is write on the tutorial and i don´t know what is wrong, i´m a beginner with flux 12.3.1.
I don´t know how can fix it, i need some help and i´d like to know if you can give me some kind a tips to resolve that inconvinient.
i hope you can give me some help
thank you...
Hello, i appreciate your quikly answer but i have already do what you tell me, and still shows me the error as the matter of fact, i have begin another tutorial and it happens the same thing when i try to build the volumes shows me the same sentence 'Some intersections may not have been detected'.
So if you have another suggestion it is realy welcome, because a don´t know how can i correct this file.
thank you...
Hello,
If the tutorial tells to use the build volume function then it means you're using the standard context so you should not enter the modeler to correct your geometry.
About the message, it is only a warning, it should appear in white or orange. Not something important. However If there are some real intersections then maybe the geometry is not correct. In this case I would check the previous steps of the tutorial to see if anything is missing or if you made any mistake.
Best regards
Hello, thak you for your answer, like i said, i´m a begginer wiht the sotfware flux 12.3.1
and i try to learn how it is works, like you said the sentence 'Some intersections may not have been detected'. it is in orange color, so i gonna keep on the next steps of the tutorial and will see what happens...
thank you my friend ...
check the geometry for intersections or something wrong or enter into the 3d modeler and correct-check the geometry. Upload the model and I try to solve It.
