I found that when I delete the export txt block (Blocks - Signal Consumer - export), the problem solved. Maybe it's because the output things are too much (120 variables, each variable to export 20000 value). But I still want to export these modeled results, is there some solutions?
When I tyied to change some attributes of this export block, "negative" out of memory error occured, see Fig below
What is the time step you are using to export the values ?? Please attach the diagram/file you are facing an issue .
Hi Girish, here is the export file panel which is labelled as red. Since I ran a 50-year simulation, the Endtime is 365*50 = 18250. Is it because 18250 is too large? But I have to export these data points...
By the way, I found everytime I changed the simualtion period, the "Fixed Interval" always changes automatically to the "Step" (0.02 here). But I want it to be just "1", so I have to change it every time (I have many export blocks). Can I make the Vissim not change my "Fixed Interval"?
How much memory do you have on your PC?
