Trouble with Tie contact
I have two 2d meshes approximately .132in apart but where the laminates will contact each other. I have been trying the tie surface contact but when I run the simulation there is no load transfer from one part to the other.
Is there any other way to perform this or something I should be looking out for in particular?
Thank you for any advice regarding this subject.
