Shell elements
Updated by Altair Forum User
Hello guys,
Can we give thickness to shell elements on one side only, instead of giving thickness to mid surface of the shell element?
Thanks.
1 - 8 of
81
For this requirement, please card edit PSHELL card and check the ZOFFS option under CONT.
You can now use the ZOFFS=TOP/Bottom option.
Kindly note that this change in thickness assignment cannot be visualized.
To do the same in 13.0, please watch the attached video
Is any one is having the soft copy of the book attached below send me
Hi,
This book is not a proprietary of Altair.
Altair offers free Ebooks which can be used for free and are available at: http://www.altairuniversity.com/free-ebooks-2/
Altair Community Member
Updated by Enrico_20294
Hi Satish,
You can either use ZOFF in PSHELL card to offset elements or use Element Offset panel.
(2D>> Element offset)
