Altair RISE
Nominate Yourself Now!
To get node id attached to a system through CELAS2 Element
User: "Vikas Kumar_22189"
Altair Community Member
Updated by Vikas Kumar_22189
Hi all,
I wants to get system which is attached to 'CELAS2' element.
                                            or
Node we can get which is attached to 'CELAS2' element. From here How we can identify that system is also attached to that node.
Is there any way to know node id from which a system is attached or can we identify whether a system is attached to a 'CELAS2' element.
I am using this code to get node id of 'origin' but it is showing zero.
# With system id
set x [hm_getvalue systems id=52 dataname=originnodeid] ;  # returning 0
# With system collector showing 0 attribute
set x [hm_getvalue systemcols id=1 dataname=attributesmax] ;
we can get node id by using Xref entities in HM for reference i am keeping image:-
<?xml version="1.0" encoding="UTF-8"?>nodeId.thumb.png.09d64f3116e7aa33765419dd2fcec250.png
@tinh or @Livil Lyle help asap.
Best Regards,
Vikas Kumar
1 - 11 of 111
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Vikas,
    Have you tried:
    set systemid [hm_getvalue nodes id=$nodeID1 dataname=outputsystemid];
    else please share a simple model with that element and system.
    OP
    Thanks livil,
    This is helpful. I never tried in reverse as you have mentioned.
    And how we can review system as shown in image. If we know system id.
    <?xml version="1.0" encoding="UTF-8"?>reviewSyst.thumb.JPG.b497882565fe00127479dd4a871d85e8.JPG
    @Livil Lyle please suggest.
    I tried below code but it is not helpful.
    *createmark systems 1 'all'
    set sysID [hm_getmark systems 1]
    *clearmarkall 1
    foreach sys $sysID {
        *createmark systems 1 'by id' $sysID
        *showentitybymark 1 1 2
        *reviewentity systems 'by id' $sys 3 1 0
        hm_redraw
        tk_messageBox -message 'see is it ok'
        *resetreview
    Best Regards,
    Vikas Kumar
    OP
    Hi Vikas,
    Have you tried:
    Hi Livil,
    Can we get system 'reference and displacement' node by using tcl\tk script.
    It's very urgent.
    @Livil Lyle @tinh
    Best Regards,
    Vikas Kumar
    User: "llyle_20499"
    Hi Vikas,
    I'm not sure of what you mean by reference and displacement, Please refer to Datanames of system and nodes which can be queried using hm_getentityvalue.
    User: "vipin_22401"
    Updated by vipin_22401
    OP
    Hi VIpin,
    But in this method how to check which is assigned node and which one is referenced node.
    It is returning both.
    Regards,
    Vikas Kumar
    User: "tinh"
    Updated by tinh
    set x [hm_getvalue systems id=52dataname=originnodeid] ;  # returning 0 because system is not defined by node it's just a system located at that position .
    User: "tinh"
    Updated by tinh
    Hi VIpin,
    Regards,
    Vikas Kumar
    As Vipin suggests
    *createmark nodes 1 'equal to value' inputsystemid $sysID
    => reference system
    *createmark nodes 1 'equal to value' outputsystemid $sysID
    => displacement system
    OP
    Thanks livil,
    *clearmarkall 1
        hm_redraw
        *resetreview
    Best Regards,
    Vikas Kumar
    And tinh,
    How we can review like this. as shown in image.
    User: "tinh"
    Updated by tinh
    Using *reviewentity is a good ideal
    OP
    Nope it's not working as shown in image.
