🎉Community Raffle - Win $25
Join and Win
Inspire's Secondary menu under PolyNURB Wrap is not showing up
User: "Ange Long"
Altair Community Member
Updated by Ange Long
I am trying to use the loop feature after using the wrap feature on an optimization run, but I can't find loop anywhere! Is this a bug or am i doing something wrong? Image as attached
1 - 1 of 11
    User: "Angel Limon"
    New Altair Community Member
    Updated by Angel Limon
    Hello Ange,
    There is not a secondary menu under the "Wrap" feature. However, if you are looking for the "Loop" feature, it can be found in the "Modify" subsection of the PolyNURBS tab. It is the topmost icon above the "Split" section. I have attached a screen capture with the highlighted cage loop feature.
    I hope that helps,
    Angel
