Issue in batchmode
Hi,
I have a tcl script that runs without any issues in the normal mode. However, as soon as i run it in batchmode (-batchmesher - noconsole) I does not run thru anymore.
I figured out that the issue arises from this command:
*setvalue props id=1 STATUS = 1 THICK=0.1
I just choose there a property and set the thickness value to 0.1. What is the problem with that in batchmode?
Cheers, J
Hmm.. tried it out with 'hm_framework loaduserprofile RadiossBlock Radioss2017' but doesn't change anything...
Could there be another reason?
Hi Tinh,
I try to set a property to the thickness 0.1. The property card is a shell element and its a radioss property card. Was that your question?
cheers, Jonas
Hi Tinh,
Ah, I got you! I first had in on 431 (from the command file), but found this '431' a little strange and thought maybe this is the cause for the error. That's why I tried out with THICK which is the property name and it seems to work. However, the initial issues remains. Does it run for you in batchmode?
Maybe, user profile in batch mode was different
