🎉Community Raffle - Win $25
Join and Win
Extracting mid-surface issue
User: "RAMGANESH"
Altair Community Member
Updated by RAMGANESH
Dear All,
I am trying to extract the mid surface for the hollow tube,but it is not extracting the mid surface as expected or by the profile.kindly give suggestions.
Thanks
RAM
1 - 4 of 41
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    which option you of mid surface you have tried?If above one is output of automid surface then go for surface pair option & check.
    User: "RAMGANESH"
    OP
    Dear Rahul,
    I had over 1200 parts in my model .how it can be done through surface pair? . kindly let me know for some other option.
    Thanks
    RAM
    Is that a plastic model with variable thickness?Auto midsurface option is the best option.If you can share same part i will try at my end in latest version.
    Note:For Complex part Hypermesh midsurface struggles to extract midsurface properly.
    User: "tinh"
    Updated by tinh
    hi,
    it seems to be not a complex part. try using option 'offset '. do not use sweep
