If the spring is physically present, one can also do some simple physical tests to estimate the stiffness (and damping coefficient too).
One should note that the damping coefficient of a system depends on the mass attached and the mass of spring itself and the medium in which it operates.
One can calculate critical damping coefficient of a spring mass system using formula 2*sqrt(k.m).
If one does not have a physical system, for a spring mass system in air, considering damping ratio of 1% which is (C/Cc) is a good initial estimate. One can further tune this damping coefficient to get a better correlation
Can you explain the last paragraph where you have mentioned that "damping ratio of 1% which is (C/Cc) is a good initial estimate" can you explain it with an example if possible. Like is there a process in play that you could share ?
Spring stiffness can be estimated from the material properties, diameter and number of coils etc.. Please refer to https://vn.misumi-ec.com/pdf/tech/mech/p2813.pdf
Regards
Praful
