I would like to know if there is any tutorial in Flux where It explain how can I transfer a 2D geometry (of a IPM Motor) that I have design in Flux to 3D module to carry out studies and simulate it.
Hi, In Flux example supervisor there is an example explaine how to create 3D project from 2D project. This example is located in : 2D example >> mlutiphysics >> vibrouacoustic analysis via OptiStruc >> create stator 3D geomtry In this example we create just the sator but it is the same principale for rotor. When you select the stator, select also the rotor and create the translation.
Hi,
Best regards.
