I should apply lift to my blade so I thought of applying it on the surface as a pressure. In this case I should consider a parabolic trend along the wingspan and then use the equation command to give the trend.
I know the total force and the area on here to apply it so I can get the total pressure. How can I spread it over this area with a parabolic trend?
Hypermesh gives you a nice possibility to write a mathematical equation to apply the pressure. So this question is about for you, not me /emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
Applied the pressure by equation?
