why ausolve does not support material model for debris flow.
Hello experts I am working on debris flow simulation with dam break condition. I tried first with simply water than my fluid (debris). There are few doubts to understand
1. I defined the air-water multiphase with outlet at downstream side but in the post processing my flow does leave the channel, or it was reversible type when i checked log file. It was showing following warning after each iteration how to fix this issue.
WARNING: inflow at outflow boundary: Outlet 1 (mass/time: in=-7.282052e-01, out=7.282179e-01)
2. when I replaced water to debris acusove exit with following error
evelset stagger "levelset":
acuSolve: No of res/lhs formations = 5 5
acuSolve: Elem.Form CPU/Elapse time= 7.970300e+01 3.038300e+01 Sec
acuSolve: Solution CPU/Elapse time= 1.337500e+01 4.056000e+00 Sec
acuSolve: Redistancing stagger "redistancing":
acuSolve: No of res/lhs formations = 20 20
acuSolve: Elem.Form CPU/Elapse time= 3.071870e+02 1.394540e+02 Sec
acuSolve: Solution CPU/Elapse time= 8.492200e+01 2.624600e+01 Sec
acuSolve: LnSlv. (host) Elapse time= 2.396200e+02 Sec
acuSolve: Total CPU/Elapse time = 4.360015e+03 1.052095e+03 Sec
acuSolve: Total Memory Usage = 1.512000e+03 Mbytes
acuRun: -*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-*-
acuTrans: *** ASSERTION in Function <adbInitLog> File <adbInitOut.c> Line <5688>
acuTrans: *** Unrecognized log item
acuRun: "C:/Program Files/Altair/2022.1/hwcfdsolvers/acusolve/win64/bin/acuTrans".exe -pb Air-debris_simulation -to cgns -out -run 0 -ts L -v 1
acuRun: *** ERROR: error occurred executing acuTrans
acuRun: Wed Sep 21 18:25:46 2022
I defined my fluid using density and viscosity vs strain rate in material model.
Seems to be an issue with converting to cgns after the run. Where do you intend to load the cgns file for post-processing? You don't need that step to convert to cgns if you intend to view the results in HyperWorks CFD.
