Hello;
How can ı see the plastic strain and von misses changes in the elements.
Hi beytut
Please goto > Global-output-request > Select Strains > and set the parameters as shown below.
Is this is what you are looking for?
If not, please explain in more detail about your issue.
Thank you
Hi @beytut
Please use HyperView, instead.
Hi beytut
Thank you
