🎉Community Raffle - Win $25
Join and Win
Macro normals
User: "flamenco7641"
Altair Community Member
Updated by flamenco7641
Hi all,
I created macro auto adjust normals:
 proc adjust_normals {} { 	*createmark comps 1 all 	*createmark elems 2 'by config' quad4 tria3 	set List_comps [hm_getmark comps 1] 	for {set n 0} {$n<[hm_marklength comps 1]} {incr n} { 		*createmark elems 1 'by collector' [lindex $List_comps $n] 		*markintersection elems 1 elems 2 		if {![hm_marklength elems 1]} {continue} else { 		set List_elems [hm_getmark elems 1] 		set ID_elems_ori [lindex $List_elems 0] 		*normalsadjust elems 1 $ID_elems_ori 0 0 		} 	} 	*normalsoff 	hm_usermessage 'Done.' }
but it doesn't work in some case, such as seperated components...
Please suggest a way to improve it.
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    If you have access to Altair script exchange.Then kindly have a look at it.You would find readily available macros for similar request.
    Regards
    Rahul R
    User: "tinh"
    Updated by tinh
    Hi,
    the better way is isolate only tria3 and quad4
    then do a 'while loop' to adjust normal for elems 'by attached', then mask them, until no elems display
    more advanced, you should care about connectivity error (two areas share only 1 node?)
    and if there are T-connection (should select base elem on the largest area?)
    OP
    Regards
    Rahul R
    Thanks Rahul, I can't access to  Altair script exchange :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'>
    Hi,
    Thanks tinh,
    Did you mean 'by adjacent' because all components are connected by rbody?
    User: "tinh"
    Updated by tinh
    Hi,
    I mean that should not loop through each component
    instead, loop through each 'attached elems area', do not care about RBODY because you isolated only tria3 and quad4
    so 'by attached' will not select over RBODY connection
    OP
    Hi,
    OK, thanks tinh
