Hello,
I am working with a custom molding and need to input thermal properties as function of temperature. It is possible ? If so how can I customize it.
Regards
Chris
Hello Chris,
You can edit mold thermal properties by creating a new material inside the mold context.
Best Regards
When you need to order injection molds, maybe you can find some professional designers, general mold manufacturing companies will give you solutions
Hello Chris,
Best Regards
