🎉Community Raffle - Win $25
Join and Win
Sum of ply failure index in composite modeling
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi to everyone.
I'm having some troubles to understand how to obtain a pure sum of two different load cases: i'd like to obtain the visualization of the sum of the ply and bond failure index, that are scalar values.
I've already tried to use derived results and derived load steps, but I still do not obtain the rigth results as aspected from a simple scalar addition
for example
load case 1 : max ply failure =0.12
load case 2 : max ply failure =0.16
what I'd like to display considering scalar is
max ply failure =0.28
thank you.
Giovanni
1 - 1 of 11
    Altair Employee
    OP
    Hi to everyone.
    for example
    thank you.
    Giovanni
    the right procedure to obtain the scalar addition is
    derived results
    problem solved.
