Create Boundary Conditions in a local coordinate system (Solver: Abaqus)
Hello there,
I need to create local boundary conditions in HyperMesh, which refer to a cylindrical coordinate system I just created. I am using Abaqus as a solver.
In the picture you can see how I do assign the nodes to the local cylindrical coordinate system.
My input file says that those nodes are assigned to that coordinate system as you can see below.
I want to constrain the DOF 2 4 and 6 but not refering to a global coordinate system.
My boundary conditions for that nodes look like this. I know that 2,4,6 does refer to the global coordinate system here, because it gives me the same results even if I do not create that local system before. Also if I open my Input File in Abaqus it says the boundary conditions "Boundaries" refer to the global coordinate system.
Is there any workaround for that? I can not find the code for the input file to change the boundary conditions to local. I know that it works for other solvers.
Thanks for your help
cluue
Hello,
Defining a reference system changes the way you define the coordinates of your nodes in your model.
This means that if you translate this system, all the referenced nodes are also moved. Their coordinates are defined on this system.
To apply a local axis to your nodes, you need to select set displacement.
I suggest you to attach nodes as set, it will be easier for you to create boundary or load on set and the input file will be easier to read.
Does it answer to your question?
Regards,
Arthur
Hello,
Regards,
Arthur
