🎉Community Raffle - Win $25
Join and Win
Error coupling Flux with hyperstudy
User: "Ramin Rahmani"
Altair Community Member
Updated by Ramin Rahmani
Hi all,
I have coupled Altair Flux with Hyperstudy, but I encountered an error during the definition step in Hyperstudy. I selected two
sensors as output components and did not use the Analyse2DCurve macro, but I am receiving the errors 'Failed to read hstp file'
and 'The PDD file does not exist.' What could be causing these errors?"
1 - 2 of 21
    User: "Karun Avula"
    Altair Employee
    Accepted Answer
    Updated by Karun Avula
    Hi Ramani,
    Thank you for contacting Altair forum.
    I hope you are using Flux V2021.2 . Have you registered the Flux V2021.2 solver script in HyperStudy? And also usage of Analyze 2DCurve macro depends on what output quantities you choose while exporting the component from Flux. What output components have you chosen?
    Thanks
    Karun
    OP
    Hi Ramani,
    Thanks
    Karun
    Hi Karun,
    Thank you for your response. The solver script direction in HyperStudy was incorrect. The problem is now solved.
    Regards,
    Ramin
