HYPERMESH - Selecting nodes via Tag Names
User: "Andy@LamteqSolutions"
Altair Community Member
Updated by Andy@LamteqSolutions
Here's a bit of a challenge and certainly one which has bamboozled me so far...
Our models need to follow a particular numbering system, we already have a code which quickly renumbers literally everything in the model to a specific number range. But an add on we would like is to be able to rapidly renumber specific node numbers. In the models, we tag nodes with a label like 'N-9001' meaning that node number must be 9001 (long story but we work on include files which must slot together so certain nodes must be certain numbers). At the moment this is a manual process but what I would like is a code which could createmark by tag name N9001, then renumber node to 9001.
Can this be done? If so, how?
1 - 6 of 61
    User: "tinh"
    Updated by tinh
    maybe: *createmark nodes 1 'by tag name' N-9001
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Andy,
    Something like this should help:
    *createmark tags 1 all
    set lst_tagIDs [hm_getmark tags 1]
    foreach tagID $lst_tagIDs {
        set tagval [hm_getvalue tags id=$tagID dataname=name]
        set tagdata [split $tagval :]
        set tagName [lindex $tagdata 0]
        //Write procedure to Modify tagname to integer if it has any string in it (Remove N-)
        set tagNode [lindex $tagdata 1]
        *clearmark nodes 1
        *createmark nodes 1 $tagNode
        *renumbersolverid nodes 1 $tagName 1 0 0 0 0 0
    OP
    Tinh and Livil,
    Many thanks for your help.
    Livil, the code is struggling (or rather I am struggling) with extracting the Node number the tag is currently applied to... this is what I get.
    (Documents) 102 % set tagval [hm_getvalue tags id=9000003  dataname=name]
    N-9004:
    (Documents) 103 % set tagdata [split $tagval :]
    N-9004 {}
    (Documents) 104 %  set tagNode [lindex $tagdata 1]
    list element in braces followed by '' instead of space
    Now I have tried
        *createmark  tags 1  'by tag name' N-9004:
     hm_getmark tags 1 (displays the right tag number)
       *createmark nodes 1 'by tag id' {*}[hm_getmark tags 1]
    But this seems to go off and find different nodes - and more of them, I was expecting 1 node but it seems to find 49!
    OP
    Success...
    set tagNode [hm_getvalue tags id=9000003  dataname=entity]
        set S1 [string trim $tagval ':']
        set tagName [string trim $S1 'N-*']
    obviously replace id=9000003 with the foreach command
    Thanks ever so much for your help
    OP
    Hmmm new problem.... here's my code
        set tagNode [hm_getvalue tags id=$tagID  dataname=entity]
    Here's the error....
    extra characters after close-brace
        while executing
    'foreach  tagID $lst_tagIDs {
    OP
    Ok weird... deleted last } then put it back in... now works like a dream!
