How to create standard channel model for 60Ghz?
Hello,
I have currently prepared my indoor floorplan on wallman. I am now looking to estimate the system required to cover this floorplan for 60Ghz. I need to apply the path loss model and figure the position of the antenna for the best tolerable interference against adjacent cells. Can someone please guide me on how to get started with this? Am I supposed to first create the antenna radiation pattern on Aman? How do I know what values needs to be assumed for the .aha and .ava files for Aman for 60Ghz? Can someone please help me with the next step?
@mvogel I appreciate your help. I am unable to access Altair Connect. Could you please send me the tutorials at your earliest convenience? Thank you once again for the much guided help in this regard.
Sure, you (and anybody else) can download them at the link below:
Filename | Size |
WinProp_v2019_Basic-JULY3-2019.zip | 401 MB |
Please click on the following link to download the attachments: https://ftam1.altair.com/message/RqQZ43zZ1T2DmK2SEU6Hb7
The attachments are available until: Friday, 26 June.
@mvogel thank you very much
Sure! Here's a link: https://ftam1.altair.com/message/fMHsVuqeoY1faFnPapqkDI
Files attached to this message
Filename | Size |
01-WinProp_v2020_Basic.zip | 335 MB |
02-WinProp_v2020_Automotive.zip | 213 MB |
03-WinProp_v2020_Telecom.zip | 194 MB |
04-WinProp_v2020_Industry_and_Rail.zip | 210 MB |
05-WinProp_2020_Aerospace_and_Defense.zip | 106 MB |
Please click on the following link to download the attachments: https://ftam1.altair.com/message/fMHsVuqeoY1faFnPapqkDI
The attachments are available until: Sunday, 9 August.
Hi, I'm unable to find the files at both the above link locations. Could you please share the files once again?
Thank you.
Hi
I tried to reproduce the AMan part of the below video :
However, I'm unable to find APA_Export2.lua
Could you please suggest how should I proceed?
Many Thanks
The script is old and is not needed anymore. The basic training materials, for which I will provide a new link, explain that WinProp can import antenna patterns from Feko directly. When you solve a model in Feko, you request a far-field pattern. Under the Advanced tab in the CADFEKO far-field request, you check the box 'Export to ASCII (*.ffe)'.
Below is a new link. Note that all these links are temporary. The file-exchange server gives the recipient a few weeks to download the files, then the files are removed.
Filename | Size |
04-WinProp_v2020_Industry_and_Rail.zip | 164 MB |
Please click on the following link to download the attachments: https://ftam1.altair.com/message/2GC2dKYH1TIBvSNMfrT9IM
The attachments are available until: Thursday, 24 September.
There are tutorials (guided exercises) on Altair connect: https://connect.altair.com/CP/downloads.html?suite=HyperWorks&tab=2 .
Log in to Altair Connect and choose Downloads from the options near the top of the page.
Under downloads, choose the tab 'Documentation' instead of 'Software'.
There is a long list that starts with installation guides. Scroll way down, past 'Tutorials' and look under 'Tutorial Files'. There will be a list to download WinProp 2019 Basic Tutorials and Models. They contain guided exercises and solved models that explain all the steps you need.
Let me know if you cannot access Altair Connect; in that case I can send the tutorials through a file-exchange site.
