🎉Community Raffle - Win $25
Join and Win
Hyperview TCL command to retrieve max displacement per subcase
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have a results file with 120 subcases.  Each subcase has its own contour plot and results.  I want to retrieve the max displacement for each subcase and write it to a file without having to view each subcase.  Ideally, I would like the legend value of the displacement to be 'fixed' not 'scientific'.   I've written a couple TCL scripts for Hypermesh, and am familiar with the puts for writing to the file, but have no idea what any of the commands are for the hyperview tcl.
1 - 1 of 11
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Here's an example of script to export all displacements of all subcase into file:
     hwi OpenStack; set hn [hwi ListAllHandles]; foreach hn1 $hn { 	catch {$hn1 ReleaseHandle} }  hwi ReleaseAllHandles   hwi GetSessionHandle session_handle session_handle GetProjectHandle project_handle project_handle GetPageHandle page_handle [project_handle GetActivePage] page_handle GetWindowHandle window_handle [page_handle GetActiveWindow] window_handle GetClientHandle client_handle client_handle GetModelHandle model_handle [client_handle GetActiveModel] model_handle GetResultCtrlHandle result_handle model_handle GetQueryCtrlHandle query_handle  model_handle GetSelectionSetHandle set_handle [model_handle AddSelectionSet node] set_handle Add all   set mydir {C:/Users/TOTO}  set num_subcase [result_handle GetNumberOfSubcases 'Base'] for {set i 1} { $i <= $num_subcase} {incr i} { 	puts 'Subcase $i' 	result_handle SetCurrentSubcase $i 	result_handle SetCurrentSimulation 1   	query_handle SetDataSourceProperty result datatype 'Displacements' 	query_handle SetQuery 'node.id,node.coords,result.value' 	query_handle SetSelectionSet [set_handle GetID]; 	set output [format '%s/displacement_subcase%d.csv' $mydir $i] 	query_handle WriteData $output; }  hwi CloseStack
    This script is not tested yet. But maybe it can give you some ideas.
