1 - 4 of
41
thanks for the reply pranav,
but i would like to restate my question once again, I have only rigid bodies in my simulation and i am applying some forces on it ....but i am getting very high nodal time step and the simulation does not run for the specified time of 15 ms. I have 4-5 rigid bodies with possible penetrations and no contact defined between each other.
regards,
If a model has only rigid bodies then Radioss will terminate on first cycle. Include a deformable element in your model (it will control the timestep) as a workaround.
Rigid bodies generally have timestep much higher than other finite elements so it is computationally efficient way to simulate components with negligible deformations.
Hi rea2
You can use /DT/NODA/CST which add mass on the node when time step drops
Refer the e-book (page 261 onwards) for more details regarding time step control
https://altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/
