Renumbering issue in Hypermesh !
Hi experts,
I am facing some issues with node/element numbering in Hypermesh14.0. when I check the min/max node/element range in renumbering panel its showing whatever I renumbered before. but when I export(displayed) into abaqus inp file, getting different node/element numbering. any solution for this?
thank you
1 - 5 of
51
Do you have includes in your model? Maybe, it wrote IDs as XML format in inp file. From v14, ID numbering rule is changed.
Try removing checkbox 'ID Rules' in export tab.
