Altair RISE
Nominate Yourself Now!
tcl programme for node move
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello
I am working on tcl programme  which will move selected node
in a vector defined by selecting nodes
I have written programme for that put node is not moving in direction I wanted
have look at programme
and how clearmark command works??
1 - 16 of 161
    Altair Employee
    OP
    hello
    so I continue working on my script
    So I think error lies in the  *createvector comand I am not able to provide proper x and y component for the vector creation
    So am I right??
    *createmarkpanel nodes 1 'select node'
    set node_list [hm_getmark nodes 1 ]
    if {[llength $node_list] == 0} {
        hm_errormessage 'no'
        return
    #*clearmark nodes 1
    *createlistpanel nodes 2 'Select direction by node1->node2'
    set vectnodelist [hm_getlist nodes 2]
    set nodeid1 [hm_getentityvalue nodes [lindex $vectnodelist 0] 'id' 0];
    set nodeid2 [hm_getentityvalue nodes [lindex $vectnodelist 1] 'id' 0];
    *createvector 1 $nodeid1 $nodeid2 0
    *translatemark nodes 1 1 5
    *clearmark nodes 1
    Altair Employee
    OP
    so finally I have found solution for this problem
        return
    #*clearmark nodes 1
    foreach {tot x y z} [hm_getdistance nodes $nodeid1 $nodeid2 0] {
        *createvector 1 $x $y $z
    set elemsize [hm_getfloat 'elemsize' 'Enter elem size']
        *translatemark nodes 1 1 $elemsize
    *clearmark nodes 1
    Thank you everyone on forum
    I have made this based on previous post only
    thank you
    User: "tinh"
    Altair Community Member
    Updated by tinh
    It's fine
    hint for you to create a vector:
    lassign [lindex [hm_getplanepanel] 0 0] vx vy vz
    (from version HM13)
    Altair Employee
    OP
    thank you tinh
    I will work on that
    I want to write a program  where while midsurfacing hm should capture the thickness of plate and auto assign it afterwards ???
    User: "tinh"
    Updated by tinh
    Hi,
    did you try using Midmesh thickness tool?
    menu Mesh>assign>Midmesh Thickness
    Altair Employee
    OP
    thanks for that I will try that option
    I want to cycle a particular tcl until I say to stop it
    so how can I do it
    like cycling particular command e.g. like program for translate and split it should continue to repeat same commands until I stop it
    User: "tinh"
    Updated by tinh
    Hi
    maybe:
    while 1 {
       *createmarkpanel nodes 1 'Select nodes to translate:'
       if {[hm_marklength nodes 1]==0} break
       #create vector and translate...
    Altair Employee
    OP
    while 1 {
    return
    #*clearmark nodes 1
    #set elemsize [hm_getfloat 'elemsize' 'Enter elem size']
    *translatemark nodes 1 1 0.196
    *clearmark nodes 1
    hm_setpanelproc {hm_callpanel 'edit element';}
    return
    so this is my program
    at the end there is a call panel so I think because of that its not working
    after I split when I press return it should return to  '*createmarkpanel nodes 1 'select node''
    so????
    User: "tinh"
    Updated by tinh
    no, the cause is command 'return' at the end
    remove it
    Altair Employee
    OP
    I tried it without return command but
    when I press return command on the edit element panel it wont return to first command
    so??
    User: "tinh"
    Updated by tinh
    yes,
    maybe you cannot use hm_setpanelproc to call a panel. this function will return immediately, moreover it will clear panel created by *createmarkpanel
    so you don't see the panel repeated by 'while' loop
    Thinking another way
    Altair Employee
    OP
    So is there any other way to call up that panel and continue the while loop??
    so how can I do this whole process other way with while loop??
    Or at least tell how to create a button on user tab I followed tut but I am not able to create it??
    User: "tinh"
    Updated by tinh
    I think it is not possible to call hm panels in a loop as you expect
    So try redefining your problem
    Your button had wrong constructor:
    *createbutton(5,'SURFACETRIM',00,5,GRAY,'Launch the succsesful.tcl script','EvalTcl','succsesful.tcl')
    should be
    *createbutton(5,'SURFACETRIM',0,0,5,GRAY,'Launch the succsesful.tcl script','EvalTcl','succsesful.tcl')
    Altair Employee
    OP
    sorry for wrong file
    I already have corrected that mistake
    still its not working?? I am win7 user and I have located this userpage.mac panel in DOCUENTS FOLDER
    User: "tinh"
    Updated by tinh
    check again initial directory
    menu View>command window
    type in :
    pwd
    ==> userpage.mac should be in that folder
    Altair Employee
    OP
    Thank you
    That worked I was placing it in wrong directory
    now it works fine
    Thank you very much
