🎉Community Raffle - Win $25
Join and Win
Query in Calling TCL script from another TCL script
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have created a UI with OK and CANCEL button. (Please refer UI.tcl)
Inside OK Command, I am calling another tcl file Sample.tcl.
Both the tcl files are in the same location
source command work fine If I provide the absolute path of the Sample.tcl.
source C:/Sample.tcl
But I am getting 'File not found error' for the following code
 variable macro_directory [file dirname [info script]];
 set tclFileName $macro_directory/Sample.tcl;
 source $tclFileName;
Please help.
Please find the codes below:
UI.tcl
package require hwt;
package require hwat;
###GUI CREATION
namespace eval ::MyNameSpace::UI {
variable m_base
variable m_master_frame
proc ::MyNameSpace::UI::CreateActionFrame { } {
#Action Frame
set action_frame [frame $::MyNameSpace::UI::m_master_frame.action_frame -height 100 -width 100];
pack $action_frame -side top -anchor nw;
button $action_frame.ok_btn -text 'OK' -borderwidth 3 -width 10 -command '::MyNameSpace::UI::OnOk'
pack $action_frame.ok_btn -side left -padx [list 337 0] -pady 10 -in $action_frame
button $action_frame.cancel_btn -text 'CANCEL' -borderwidth 3 -width 10 -command '::MyNameSpace::UI::OnCancel'
pack $action_frame.cancel_btn -side left -padx [list 20 0] -pady 10 -in $action_frame
proc ::MyNameSpace::UI::DestroyDialog { } {
#Delete m_base
if {[info exists ::MyNameSpace::UI::m_base]} {
destroy $::MyNameSpace::UI::m_base
proc ::MyNameSpace::UI::OnOk { } {
proc ::MyNameSpace::UI::OnCancel { } {
proc ::MyNameSpace::UI::Main { } {
#Delete if m_base exist
#Set value for m_base
set ::MyNameSpace::UI::m_base .bjaDialog
toplevel $::MyNameSpace::UI::m_base
#Dialog title
wm title $::MyNameSpace::UI::m_base 'My Script'
wm resizable $::MyNameSpace::UI::m_base 0 0
#Create Master Frame in Base
set ::MyNameSpace::UI::m_master_frame [frame $::MyNameSpace::UI::m_base.m_master_frame];
pack $::MyNameSpace::UI::m_master_frame -side top -anchor nw -padx 7 -pady 7 -expand 1 -fill both;
#Create Action Frame and add to Master Frame
#Call Main
::MyNameSpace::UI::Main;
Sample.tcl
namespace eval ::MyNameSpace::MyScript {
proc ::MyNameSpace::MyScript::Main { } {
tk_messageBox -message 'Hello World!';
::MyNameSpace::MyScript::Main;
1 - 2 of 21
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    In your case you should put info script command in body of namespace eval
    (do not put it inside body of a proc)
    Altair Employee
    OP
    Modified as per you reply and it is working. Thank you very much.
