Getting Access To Aspect Ratio Values
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys,
I'm working at a customization problem. During a loop an automesh should be executed when the mesh criterium 'aspect ratio' exceeds a specific value.
Do you have an idea how I can get access to the aspect ratio values after each iteration?
Kind regards
Simon
1 - 5 of 51
    User: "Jeffersondhv"
    Altair Community Member
    Updated by Jeffersondhv
    There is a variety of functions you can use to achieve this:
    *elementtestaspect Help
    hm_createmark elems 1 'greater than value' 'aspect 3' Help
    hm_getelemcheckbounds Help
    I hope this can help you achieve what you intend.
    User: "vipin_22401"
    Updated by vipin_22401
    @Bachelor22,
    use hm_getelemcheckbounds
    Altair Employee
    OP
    Thanks guys, that was exactly the command what I was looking for!
    Altair Employee
    OP
    Is there a way to get access to the fail values of the different quality criterias set in hypermesh?
    Kind regards,
    Simon
    Kind regards,
    Simon
    Yes, check the help linked with the functions mentioned to see the options you have:
