🎉Community Raffle - Win $25
Join and Win
Solid map, mappable view option
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I used 'mappable' view option in the visualization toolbar.
My geometry is complex, so I divided it into several pieces, then the whole model became yellow and transparent from orange color.
When the color of a piece turned to yellow, I was able to create hex elements.
So I created hex elements for piece by piece, but at some point I could not create hex elements, and got an error message which said
'Selected volume is not mapplable.'  But actually the color of the piece is still yellow.
I assume that when the color is yellow, I am supposed to be able to use solid map to create hex elements.
But I got error messages.
Can anyone help me with this problem?
I would appreciate any help.
Thanks,
Jay
1 - 3 of 31
    Altair Employee
    OP
    Hi,
    do you have used 3D->solid map->one solid or multi solid at any step?
    Hexmeshing is a difficult issue, sometimes it is not possible to create a nice hexmesh and sometimes it is not possible.
    Try to make extra cuts and seperate the difficult solids. Maybe it helps.
    Regards,
    Mario
    Altair Employee
    OP
    I used both one volume and multi solids.
    I divided into really small pieces, and still cannot create elements.
    Altair Employee
    OP
    Hello,
    sry but i can't say more, since the next step is to look at the model ;-)
    Try to contact your local Altair hotline support.
    Regards,
    Mario
