Hi,
I am using inspire to optimise a rocker model, but each analysis terminates at 40% completion and 'hvtrans.exe has stopped working' window pops up.
Can you tell me what's wrong with my model and how to fix this please?
Thank you
Yan
Hi YanYang2,
could you please let us know which version/build of sT Inspire are using?
to check the build of sT Inspire, Go to Help and click About to view version and build details /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Yan,
Please see if you can also share the model using the secure dropbox link below
Hi Prakash,
I am using ST inspire version 2014 build 3959.
Hi Rahul Ponginan,
I will try and upload now.
Thanks
can you install the latest build Inspire (3969) from http://www.solidthinking.com/DownloadProducts.aspx?category=Download&item=Products
Run the optimization again and check if you are able to get results without errors.
if you still face the problem, please let us know.
yanyang2
Thank you Prakash and Rahul, that was really helpful! It was my applied load and support on the model that caused the problem as you suggested.
