Altair RISE
Nominate Yourself Now!
User defined Output request causing error in "Static Ride Analysis event"
User: "Sudip_Chavan"
Altair Community Member
Updated by Sudip_Chavan
Hi
I am simulating a custom made double wishbone model with static ride analysis event, and trying to extract ride steer, caster and camber using following function:
`USER({MODEL.sys_misc.ds_report_ms.scale_index.value}, 180, 1, {sa_testing_parameter_array.id, %d}, 0, {sa_vehicle_parameter_array.id, %d})`
The simulation works perfectly if that output request is deactivated, when it is activated the log files shows solver failed and Error written as,
INFO:    ALL:  10705150  11102020  20705150  21102020  30903100  3094100
ERROR:    Marker  [id=11101]  not found in SYSFNC!
ERRMWS: USER  [11101]
sdf_wcdata: Error calling sysfnc for left constraint force.
** EXECUTION STOPS DUE TO ENDFLG IN USER SUB **
Abnormal return from processing model!
ERROR: Simulation failed due to error encountered in analysis!
Marker with id 11101 are following markers which all are located & oriented correctly as per my template reference model
1.WC marker at ground, 2.Jack CP marker, 3.Upper steer axis, 4.Ground Patch Marker
And Left Verical Actuator force is also verified from reference model.
Any help would be greatly appreciated
Best regards
Sudip Chavan
1 - 7 of 71
    User: "GTT Adam"
    Altair Employee
    Updated by GTT Adam
    Hi Sudip,
    If you are having trouble with the USER subroutine, you could always just measure the caster, camber, and tire steered angles through Expressions. Simply place a Marker attached to the knuckle which is located at the tire center and aligned with the Global Frame Marker. Measure the rotational displacement (AZ) of the new Marker with respect to the Global Frame Marker for steer angle. Measure AX for the camber angle. Lastly, align the Z axis of a second marker along the shock / AutoDamper entity and measure AY with respect to the Global Frame Marker as well to calculate the caster angle.
    Hope this helps!
    Adam Reid
    OP
    Hi Adam,
    Thank you for your reply! It works.
    But as reference to all template models they have defined Suspension Design Factors (SDF) Requests with use of USER Subroutine, with ref to Local File : msautoutils
    I was actually trying to do the same for easy and fast post processing of the model.
    Can anyone help me out with above USER Subroutine error with reference to local file msautoutils
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hi Sudip - would you be able to share your model ?
    Praful
    OP
    Praful
    Hi Praful,
    Yes, I can share my model as it only includes default modelling parameters and not related to any other specific product.
    Can you provide any info to share that model to you?
    Thanks and Regards,
    Sudip Chavan
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hi Praful,
    Thanks and Regards,
    Sudip Chavan
    Hi Sudip - If the model is not confidential, you may attach the mdl & any other reference files when you reply.
    Else, drop the files at this drop box > https://ftam1.altair.com/filedrop/ppraf@altair.com
    Regards
    Praful
    User: "Praful"
    Altair Employee
    Accepted Answer
    Updated by Praful
    Regards
    Praful
    Hi Sudip
    Thank you for sharing the model. I did a quick review. I see you have edited  Solver Array  testrig_parameter_array.
    &nbsp; &nbsp; *SetSolverArray(sa_testrig_parameter_array, VALUE, 17, mrk_wc.l.id, mrk_wc.r.id, mrk_kp.l.id, mrk_kp.r.id, mrk_grnd.l.id, mrk_grnd.r.id, <span style="color: #f1c40f;">frc_jack_vertical_actuator.l.id, frc_jack_vertical_actuator.r.id, frc_jack_vertical_actuator.l.id, frc_jack_vertical_actuator.r.id, </span>MODEL.sys_steering.j_1.i.id, -1, ds_steering_actuation_application.int_api_value.value, mrk_upr_mnt.l.id, mrk_upr_mnt.r.id, mrk_jack_cp.l.id, mrk_jack_cp.r.id)
    I think the function expects markers in the 7th to 10th arguments. What you have referred are force ids !
    frc_jack_vertical_actuator.l.id is the id of the left side of force frc_jack_vertical_actuator.
    To rectify it, you need to add .i and .j
    &nbsp; &nbsp; *SetSolverArray(sa_testrig_parameter_array, VALUE, 17, mrk_wc.l.id, mrk_wc.r.id, mrk_kp.l.id, mrk_kp.r.id, mrk_grnd.l.id, mrk_grnd.r.id, frc_jack_vertical_actuator.l<strong><span style="color: #169179;">.i.</span></strong>id, frc_jack_vertical_actuator.r<strong><span style="color: #169179;">.i.</span></strong>id, frc_jack_vertical_actuator.l<span style="color: #169179;"><strong>.j.</strong></span>id, frc_jack_vertical_actuator.r<span style="color: #169179;"><strong>.j.</strong></span>id, MODEL.sys_steering.j_1.i.id, -1, ds_steering_actuation_application.int_api_value.value, mrk_upr_mnt.l.id, mrk_upr_mnt.r.id, mrk_jack_cp.l.id, mrk_jack_cp.r.id)
    After this change, I was able to run the model successfully.
    Regards
    Praful
    OP
    Hi Sudip
    Regards
    Praful
    Thanks for the info!
    It worked.
    Thank You.
