🎉Community Raffle - Win $25
Join and Win
How to specify static displacements on set of nodes(non zero)?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi...Everyone.....
       I have to do linear static analysis. I want to do specify static displacement on set of nodes, i have used DAREA to specify the same. But i am getting unreasonable results. Is there any other way to specify the static displacement on the node?.
Thanks in advance image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
Ramsubramanian
1 - 4 of 41
    Altair Employee
    OP
    Hi Ramsubu93,
    Try with SPCD instead and check whether you get expected results or not.
    Altair Employee
    OP
    Thanks sir.........
    But in Linear static loadstep, where to refer the SPCD?
    Can i refer SPCD in DEFORM?
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    First you will need to create a SPCD on the required nodes, this will be in a load collector.
    Then you need to create a SPC load collector and constrain the DOFs specified in SPCD in this SPC collector,
    Then Reference SPCD load collector in LOAD , and SPCs in SPC section of the loadcase.
    Altair Employee
    OP
    Thanks a lot sir.......
