can not find the file command.cmf
Dear all
I want to find the command.cmf file. But I could not find it under the start directory.I did as follows. Where am I wrong? thanks!
1. Locate and right-click the relevant HyperWorks Desktop application icon from the Start menu Altair HyperWorks <Version> group.
Or
Locate and right-click the HyperWorks Desktop executable file (e.g. <altair_home\hw\bin\<platform>\hw.exe)
2. Select Properties to open the properties dialog.
3. Select the Shortcut tab.
4. Edit the Start in field to contain the path to the directory in which you want to run the HyperWorks Desktop application. This directory becomes the start-in directory.
5. Click OK.
6. Start the HyperWorks Desktop application as defined in the 'Starting HyperWorks Desktop Applications' section.
