Is there a way to create row numbers that count only when a value changes ...
User: "Justin_21746"
Altair Community Member
Updated by Justin_21746
Hello,
I was wondering is there a way to create rows numbers that count only when a value changes, i.e. three rows of data, the first two row ids are CD and the third is TAPE, I would want it to restart the row count when the value changes from CD to TAPE.
Justin Marroquin
Financial Analyst
Dssw, LLC
San Antonio TX
(210) 845-6651
1 - 3 of 31
    User: "Baba_Majekodunmi_703"
    Altair Employee
    Updated by Baba_Majekodunmi_703
    Hi @Justin Marroquin,
    I'm not sure this is possible in the way you're approaching it, but I am confident there may be another way within Monarch to address the your challenge.
    can you tell us a little bit more about what your goal is? What will having the row numbers changing dynamically help you accomplish?
    Baba Majekodunmi
    Solutions Consultant
    Altair Engineering Inc.
    Troy VA
    2405932495
    Original Message:
    Sent: 11-13-2020 12:39 PM
    Subject: Is there a way to create row numbers that count only when a value changes ...
    Hello,
    Justin Marroquin
    Financial Analyst
    Dssw, LLC
    San Antonio TX
    (210) 845-6651
    User: "CPorthouse"
    Altair Employee
    Accepted Answer
    Updated by CPorthouse
    Hopefully the following makes sense.  I am using classic.prn to create this example.  I skipped the modeling portion.  Once you have the data modeled, I added a couple of metadata columns (ReportPage and ReportLine):
    I then grouped my table (Transform -> Group) on Order number and Media and aggregated on ReportPage and ReportLine (using the minimum):
    I then combined by GroupBy table with the original Classic table using Combine->Join Tables->Lookup:
    This will bring back the first row for each value change (Order # and Media).
    Add a formula column to calculate the difference between the minimum reportline and the original one and add 1 (so it won't be zero based):
    Hopefully this gets you started.
    Chris Porthouse
    Professional services
    Altair
    Original Message:
    Hello,
    Justin Marroquin
    Financial Analyst
    Dssw, LLC
    San Antonio TX
    (210) 845-6651
    OP
    Chris Porthouse
    Altair
    Original Message:
    Hello,
    Justin Marroquin
    Financial Analyst
    Dssw, LLC
    San Antonio TX
    (210) 845-6651
    Thank you, I implemented these steps into my solution and works just like I need it to. This tool continues to serve so many purposes.
    Justin Marroquin
    Financial Analyst
    Dssw, LLC
    San Antonio TX
    (210) 798-0123 Ext. 1913
    Original Message:
    Sent: 11-16-2020 09:50 AM
    Chris Porthouse
    Altair
    Original Message:
    Hello,
    Justin Marroquin
    Financial Analyst
    Dssw, LLC
    San Antonio TX
    (210) 845-6651
