I want to create stress in BCs
Karshenas Reza
Karshenas Reza Altair Community Member
edited January 2022 in Community Q&A
hi
I want to create two type of stress on a rotor: shear stress and normal stress. Because the surface is circle, I cant find an easy solution to apply pressures normal and paralle to surface. also can you offer me a methode?
Welcome!
Answers
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    edited January 2022
    You can create normal forces as a pressure.
    You can use a cylindrical coordinate system to define forces in the tangential direction (y-axis).
    You can also create normal forces with the same cylindrical coordinate system (radial, x-axis).
  • Karshenas Reza
    edited January 2022
    thanks for answer. but as pressure it is not possible to use a local coordinate system like cylindrical or spherical. is it? there is no option to choose different local coordinates, but only globale.
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    edited January 2022
    Right you would use a pressure to create a normal force or a coordinate system to define normal loads.  The only way I thought of creating parallel surfaces was with a coordinate system.
  • Karshenas Reza
    edited January 2022
    ya, got it, thanks for tips. helped me.
Welcome!
Welcome!
