Thank you @Pranav Hari, @Prakash Pagadala
Actually, before I writing I worked steeringwhell_hexa.pdf but I didn't understand well.
Do you have any other video to guide me?
Hi @Aslan
There are a few videos available on youtube, you can refer to those. There is no thumb rule or straight procedure available for hexa meshing.
Thank you for helping @Prakash Pagadala
Actually, I watched the videos and other all videos /emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
But I don't fully understand, what should I think do for solid edit.
Thank you.
Hi @Mrt
You can get it from here https://altairuniversity.com/learning-library/hypermesh-12-0-hexa-meshing-a-steering-wheel/
@Pranav Hari thanks a lot.
i saw it folder in altair site=)
there are many books/videos/manuals but difficult to search that you need=)
We are improving our system consistently along with adding new learning material on Learning Library.
thank you for everything @Prakash Pagadala
I don't understand what we want to do solid edit(Trim)
I'm trying but probably part is the most difficult in hypermesh
How will we decide to be a trim area?
And soryy /emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' /> Can you share your full file.
You can start by trimming solid with lines. Since it is easy to divide the solid into small chunks with lines, I prefer to start with trimming by lines and 99% is done with trim with lines.
The model I shared, is the complete model...
Thank you for everything @Prakash Pagadala
I am trying, I hope I can /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Hi Busra Aslan
Can u share with us more details about the model or a snippet of it.
