any one know about solid editing pannel
Answers
Hi,
no one responds because they don't understand what your problem is, perhaps
where is the exact portion you want to split?
unlucky, I cannot open your file by hm13, export it to step geometry please
0 -
0
sorry. I don't understand what you want to do. How can I help you
/emoticons/default_wacko.png' title=':wacko:' />
0 -
@tinh how to trimmed model, i try to trimmed in solid model but i cannot trimmed actual trimmed , but its trimmed zig-zagly,please check below video
0 -
Sorry man, I don't understand how you want to trim it
why you selected yellow lines and trim by 'sweep'?
0 -
i want to trim to steering outer ring by using yellow region , then only i do 3d mapping mesh so how to to do,
here i attched pdf file in tutorial
i do step page number 14 end part
0 -
I got it
Please change option 'sweep to' to 'by a vector' instead of '1 or 2 end nodes'
if you don't want to trim opposite side, specify a distance by 'input field' instead of 'sweep all'
0
