🎉Community Raffle - Win $25
Join and Win
Difference between Euler's critical load and Buckling Analysis "F" parameter
User: "LFSS"
Altair Community Member
Updated by LFSS
Hello, all
I've got a trussed structure I'm woring on, but when I call a buckling analysis, it gives me this result:
But, when I extract the element forces via ELFORCE, it gives that, in that particular member, Ive got a 167N force, which I used to calculate manually Euler's critical load. Pcrit equals 42N, but the F paramenter in OptiStruct (which should give the ratio of Euler's load with the acting load) gives me a far lower ratio. Any clue why that is?
thanks in advance!
