🎉Community Raffle - Win $25
Join and Win
While performing Dynamic analysis on a Chassis (made of AISI 4130 Chromoly Steel), when assigning the material what should we select for type and card image option?
User: "Rijin Raj"
New Altair Community Member
Updated by Rijin Raj
Confused on which type of material and which card image to choose :(
1 - 1 of 11
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Hi,
    it would be nice if you take a look at the Radioss documentation for a better understanding of what material models Radioss supports. All these different types should be there.
    But usually, for a elasto-plastic material, you would use MAT2 or MAT36.
    MAT2 uses the JohnsonCook equation/parameters for building the plastic curve.
    MAT36 can be used if you have the actual plastic curve (stress-strain).
    If you're new to explicit simulations, I suggest you to go through the Radioss e-book, first:
    https://altairuniversity.com/free-ebooks/
