renumber stl file according to a pattern and direction
Rahul_P1
Rahul_P1
Altair Employee
edited October 2020 in Community Q&A
HI,
I have a STL Mesh file imported into hypermesh. Checking the order of the nodes , I noticed that the node ID are not in the order. Now, I wonder how I can renumber the nodes based on specific pattern and direction.
I will be grateful if you guide me.
Peyman
Answers
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited May 2015
    Perhaps these below are the scripts you are looking for, script 614 and 313 are more relevant.
    You need to download the script and then run this script from the downloaded location by going to file > run tcl tk from within HyperMesh.
    see http://www.altairuniversity.com/support-forum/?mingleforumaction=viewtopic&t=87
    you will find this and other scripts in the altair script exchange, go to learning > script exchange from the altair university website or here http://www.altairhyperworks.com/Script-Exchange.aspx?%3ftop_nav_str=1
    you will need to log in with your university mail id and login credentials you get after registering to the client centre.
    search for the script by just entering renumber in the keyword section.
    once you have found the script click on the download button, once you have downloaded the script place it in a convenient location, then you need to do a file > run tcl tk from within HyperMesh. make sure you have a relevant model loaded in HyperMesh when you run the script.
Welcome!
Welcome!
