Hey everybody,
I want to perform a linear static analysis on a model consisting of shell and solid elements. The different shell element parts are connected to each other wire rod elements (CWELD, optistruct) to present a weldseam. How can I realize the weldseam connection between the shell and solid element parts? -I tried to take the rod elements as well, but in the output file there occurs an error like 'the chosen grids are no vertex grids'. The use of rigid elements is also impossible, because there are multiple rigid elements connected to a single grid during the automated generation (area + realize) which causes an 'degree-of-freedom'-error.
I´ll be thankful for every comment.
The picture below shows a relevant section from the model.
