Sir TEMPD1 and EIGERL is now showing in my hypermesh panel.
In the newer versions, EIGRL is not a "load collector" anymore.
You can look for "loadstep inputs" instead. The name has changed, but the function/card is the same.
Or much easier, use Ctrl+F, and type EIGRL, and a new loadstep input of type EIGRL will be created in your model.
