RB2 connection between list of nodes
Hello i'm having problems with rb2 connections i need to join different large surafaces and i wish to know if there is a tecnique that allow me to select different numbers of nodes and connect it to o the other surface. i will post an image to explain it. i wish to create a list of nodes and connect it to the other list
do you want connect 'node to node'?
or 'node to node set'?
This video on RBE2 connection may help you..
https://altairuniversity.com/learning-library/hypermesh-1d-rigids-bars-and-beams/
i wish to coonect' node to node' each element. But i'm not able to create a node list . how can i do? yes two componets have the same mesh size.
Hi,
Try this,
Go to 1D>> COnnectors>> Spot. Change the weld type to Rigid, select the nodes, components to connect and click create.
i followed this procedure but it doesnt's work. I select the nodes and when i press create everything disappear.
Maybe this video will help?
The distance between two plates is 5 units and used rigid lo connect.
thank you for your help but i didn't solve this problem i need to link nodes from 1 to 6 with node from 8 to 13 that are in the same middle surface but they are two different components.
If it is only those nodes you can use rigid, select the nodes and create the RBE2
If mesh sizes are same, 2 node lists should be same
