Element Orientation
Hi Experts,
I am just a beginner and faced the below problem.
for one of the metallic part model, I have different element orientations for elements (It is not consistent for elements of same part which modelled by automesh option). If I make them using N1-N2 ,. Though it is a metallic material part, my customer would like to get it consistent.
Is there any way to do this? Finally I need to assign all nodes to a cylindrical coordinate system. Will it create again the problem with element orientation.
Please support with your suggestions. I m using 2017.2 version.
Thanks and Regards
Nithin
Hi Guys,
Thank you for feedback. But unfortunately, this is not what I am looking for.
The material is metallic, not composite.
element normal are in one direction, but the element orientations are not. This is the problem. If I make orientation in one direction, normals getting disturbed.
Hope my problem is clear now.
Hi,
for material orientation review/edit use 2D>composites>material orientation panel.
To assign nodes to a cylindrical coordinate system use analysis>system>assign panel. In the same panel, there is also an option for material orientation.
