🎉Community Raffle - Win $25
Join and Win
Hypermesh - select elements by geometry
User: "bharathkoya"
Altair Community Member
Updated by bharathkoya
Hello everyone,
I think this is a basic question, but I am unable to get it working. I am using Hyperworks 14. I have a block of solid hexagonal mesh and I am trying to add new components by selecting a subset of the elements. I am trying to work  with the 'organize' panel option, but I had no success so far.
To test it, I created a huge cube filled with hexahedral elements and a small rectangular surface within the cube. I was able to associate few of the nodes by doing 'Geometry ----- node edit ----- associate' and selecting the rectangular surface and small tolerance level. It shows that I have some of the nodes associated to the surface component. Now to select a subset of elements within the cube,  I did 'tool ---- organize ----- collector ----- elements ------- by geometry ------ by surface.' It doesnt show any elements associated to this surface even though I have a few nodes associated to it. Could you please help me figure this issue?
I checked other questions in the forum, but they dont help because I have a complex geometry to select elements for.
Here is a small screenshot of what I am doing.
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b13bd436c1bda7f2f0bd29175e283346.png
I am following the directions from the help documentation below ('by geoms'):
Thank you for all your attention,
Bharath
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Hi,
    You have to associate them to solids and select by geom>solids
    selecting 'by surface' is just used for 2d elements
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    @tinh is right.
    Selecting the 'by surface' option works only for 2D elements not 3D.
    You need to use 'solide option.
    Thankyou'
    User: "bharathkoya"
    OP
    thank you @tinh
    Selection 'by solid' is working after association of the nodes is done.
    Thank you,
    Bharath
    User: "Nikolai"
    Updated by Nikolai
    Can someone please tell me how to associate geometry to a mesh respectively how to associate surfaces or solids to nodes/elments in Hypermesh? Thank you.
    User: "Nikolai"
    Updated by Nikolai
    Can anyone please tell me how to associate geometry to mesh respectively how to associate surfaces/solids to nodes/elements? Thank you
