🎉Community Raffle - Win $25
Join and Win
2D meshing thickness variations along features
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
While assigning thickness in 2D meshing ,why the thickness variation along features like ribs in plastic parts should be generally in 0.2 mm or more range .What is the technical reason behind this?
Thanks in advance
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Plastic parts could have uniform or varying thickness.It depends upon the application where part is going to use.
    Hypermesh allows you to enter uniform or varying thickness using property card.Let us know if you are in search of any automatic method for assigning variable thickness on rib or any part.
    User: "kalaiselvan_22516"
    Updated by kalaiselvan_22516
    Hi,
    I need some guidance regarding plastic mesh of some complex component..Am doing it manually using surface pair, mid line , offset options..Is there any reference model which have been done already..i just need  any plastic CAD model before  and after midsurface extraction for reference purpose..
    User: "Nachiket Kadu_22143"
    Updated by Nachiket Kadu_22143
    Hi @Rahul R
    I know changing nodal thickness by card edit of shell. 'Varying thickness using property card' can you please elaborate this?
    Altair Employee
    OP
    kalaiselvan
    May i know what is the issue you are facing?
    Thank you
    Hi @Rahul R
    Can Anyone enlighten me with this varying thickness using property card (Apart from nodal thickness)?
    Altair Employee
    OP
    Hello,
    First you need to extract the midsurface
    Then you can use any of the following option
    1)Create Different properties
    You can organize the elements of different thickness in different components. then respectively create properties for them with the correct thickness and then assign them.
    2)Utility menu>Geometry mesh>midsurface thickness
    This option will consider the existing elements for assigning the thickness. Here you are allowed to do the surface editing. But the surface which you are meshing should be extracted mid surface of the required Geometry.
    3) Menu>>Assign>>Midmesh Thickness
    <?xml version="1.0" encoding="UTF-8"?>image.png.4a6962e1f1d7053bad6d666da58c8530.png
    This is the best option as you can select the elements and apply the thickness.
    Thankyou
