1 - 3 of
31
Hi,
You are welcome.
Unfortunately, we don’t have any example on this topic.
About the sensors, from Flux supervisor example there are an example on which we use a sensor (for example IPM motor).
For the case you want to use a sensor in the electrical circuit, form I/O parameters (data tree >> parameter quantity):
Select sensors >> new >> type of sensor: predefined >> select for example magnetic flux (stranded coil conductors)
Best regards.
Hi,
There is an example in the help of Flux which shows the steps to follow to make the coupling between Flux and Matlab Simulink.
file:///C:/Program%20Files/Altair/2019/flux/Flux/Help/Flux/english/Website/index.html?LoiDeComportementMagnetiqueBHGeneralites
In the search put Matlab you will get all the information
Yes, it is possible to simulate a generator in Flux.
What do you mean by alternator coupling (Flux/Matlab Simulink coupling? Or Motor/Generator?
Best regards.
