🎉Community Raffle - Win $25
Join and Win
FSAE Kinematic Analysis Outputs
Hi everybody.
I am currently running a kinematics analysis on a FSAE vehicle in MotionView.
The question is: where can I find information about the outputs generated by the different simulations?
When running a 'static ride' simulation, and showing the report, common data is shown as: camber gains, bump steer, etc. I am missing the data regarding motion ratio between wheel displacement and damper stroke, data from roll centers, etc. I have looked in the user guide but there’s few information. Also, I think this information must be clear in order to perform a optimisation in HyperStudy.
I attach a picture where I show the results regarding Wheel Rate data, so that everybody sees what I mean.
If these outputs I’m missing are not generated by the templates, how can I custom build one?
Thank you in advance, kind regards.
1 - 3 of 31
