Is there any script to get the component ID if the component name is known?
1. comp_name = Random name was set. Same name component is made.
2. I was running this code but it is not selecting the desired component. Message is showing "No change. Total selected 0".
hm_createmark comps 1 "by name only" "$comp_name";
3. I wanted to know if we can get component id if component name is stored in variable.
1 - 1 of
11
set comp_id [hm_getvalue comps name=$yourname dataname=id]
